Salta al contenuto principale
Installing OS X 10.6 fail
I'm trying to install OS X 10.6 on my MacBook Pro 2,2 2.16 Ghz.
Now running 10.4.11
Install disk is CPU Drop-in DVD 10.6 (2z691-6431-A)
Specs:
MacBook Pro 2,2 15",
Intel Core 2 Duo,
2Gb Ram (2xDDR2 SDRAM 667MHz),
Bus speed 667 MHz,
320 Gb HDD 7200 rpm,
Boot ROM: MBP22.00A5.B07,
SMC Version: 1.12f5,
For some reason my build-in speakers diappeared from my system setup, so I have decided to make a clean install from OS X 10.4.11 to 10.6, all my data have been transfered to an external harddrive and I'm ready to erase/format my internal harddrive.
When I'm trying to boot from install disk, I'm asked to choose language, then it starts to prepare the installation, but a pop-up says that I need to have 10.5 or later installed to install 10.6 and I can only choose to "Restart" or "Repair Disk"
Question: Is there a problem between my hardware and the 10.6 installation disk?
Can I resolve this?
Any ideas ??
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There are a couple of possibilities here:
Your system currently does not have the newer Journaled HFS+ formatted HD as over time you've updated the OS without reformatting the HD. Did you have OS-9 on it?
The disk it's self has a problem so the installer thinks it needs to repair the disk
In either case the solution it the same this disk needs to be repaired and/or reformatted.
You might think about installing a new HD (larger and/or faster) and holding this one as a backup by installing it into a external F/W or USB2 case (F/W being best in this case).
Punteggio 1
Aggiungi la tua risposta
Niels sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 508
