Salta al contenuto principale
La seconda generazione della Mazda 3 , nota anche come il Mazda3 e Mazda Axela , berlina e station.
10 Domande Visualizza tutte
D/S window is not working!
I have a (2010) Mazda 3 sedan & my Driver Side window suddenly doesn't work , but the other 3 window works fine. I'm curious if it could be the motor or switch? How do you remove the switch panel as well? Thanks everyone!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi Johnny,
It could be the switch/regulator. I would start from there. Then I would check the motor of the window.
Here are the instructions on how to remove the panel. A guide with images (although for a 2004 model) you find here.
I am not sure if this would fit your model/make and if at all necessary, but check this out.
Steffen
Punteggio 1
Hey, I attached the interior trim workshop manual from Mazda for this specific vehicle
2010_Mazda_3_Interior_Trim_WORKSHOP_MANU.pdf
Serge
Punteggio 0
Aggiungi la tua risposta
Johnny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 22
Tutti i Tempi: 6,780
