Salta al contenuto principale
Guide per riparare e disassemblare telefoni di ogni marca e compagnia telefonica, inclusi iPhone e Samsung Galaxy. Procurati tutto quello che ti serve per riparare il tuo telefono da solo.
73576 Domande Visualizza tutte
Domanda Chiusa
which are the components that are damaged more frequently?
Hello, my question is about the motherboard of a mobile, which are the components that are damaged more frequently? There is any way to separate them from the others components? This could made the device more repairable. If possible is it worth it???
Thanks you!!!
G.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Giovanni Riva, that all will depend on what type of damage and what model device. Water damage can most certainly ruin most components on any board. It will depend on if it was powered on or off when it susrained the damage. Of course, current carrying components will shorten out quickest. That is the reason for not turning on the device and to remove the battery. Dropped damage will most certainly damage the LCD's, the battery, crack the logic board, and tear the cables. As you can see it all depends....:-)
Punteggio 0
1 Commento:
Ok, understood!!!
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 106
