Salta al contenuto principale
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 Domande Visualizza tutte
How hot must I set my heat-gun during re-flow?
I have my own heat-gun, and am planning to re-flow my xbox before I install the RROD kit. The instructions do not say how hot to set the heat gun during both the bit when the motherboard is up-side down and then the right way up, it only says low and high, respectively. Just wondering what sort of heat ranges I should be working at during these stages. (It'd be a bonus if answer could be in Celsius, but just whatever really).
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You should warm up your notherboard ( a Griddle will work fine) until the top of the board reaches about 120C, then bring the heatgun over the top of the GPU and keep it around 20-25cm initially, going in small circles over the GPU - keep it moving. If you can, use an IR thermometer (Thermocouple thermometer would be perfect) to keep an eye on the temps. You want to take the temperature to 230C. When you reach this temperature, hold it there for no more than 10 seconds, at this point the lead free solder balls will be properly melted. Make sure you do not touch anything or move anything against the board at this time until the board has cooled down. Hope this helps, good luck
Punteggio 1
Aggiungi la tua risposta
Josh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 360
