Salta al contenuto principale
Amazon's second generation e-reader with a 6'' e-ink display, five-way controller, and QWERTY keyboard.
"Broken screen - can it be fixed or replaced?
My kindle 2 screen is no longer working. It's mostly blank but does
have some horizontal and vertical lines on it. I've looked at your
kindle 2 break down and it looks like the guts of the kindle are
attached to the screen. If I'm wrong, can just the screen be
replaced. Can't find anything on the internet for just the screen but
am hoping you may be able to help.
Questa è una buona domanda?
Punteggio 4
1 Commento
You'd better do the DIY repair if you know the technical skills of disassembly device. Or, you'd better ask help from expert.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well, Susan, maybe today is your lucky day!...
The display can be bought from China suppliers at Ali Express. I checked and found one that is selling the display for US$ 34.88 with free shipping, via China Post Air Mail (delivered between 15 to 26 days) or via DHL, paying an additional fee of US$ 37.89 (delivered between 3 to 7 days).
Please check at http://www.aliexpress.com/item/Original-...
You can also check for other options searching for "Kindle 2 display" or "Kindle 2nd Generation display" inside Ali Express. You can also search for the display part number: ED060SC4(LF)
The screen is glued to the printed circuit board via two-sided tape, forming kind of a frame. Inserting a plastic tool between the display and the printed circuit board and moving it around the borders of the display will make it detach from the circuit board. Check the Kindle 2 tear down guide to see how the adhesive tape is laid behind the display.
Another option, considering that the display is already broken and is not going to be used anymore, is to heat up evenly the front of the display with a hair dryer, while trying to raise the display with the help of the plastic tool. Take care not to heat the whole set up too much, only the display, to soften the adhesive from its back and ease the removal operation.
Hope these tips may help you have your Kindle 2 working again! Good luck!!!
Miguel L. Martins
Punteggio 2
Aggiungi la tua risposta
Susan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,115
