Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2201 Domande Visualizza tutte
Domanda Chiusa
Screen and loud speaker issues!
I replaced the broken plates on my iPhone, front and back. I've got two issues:
1-The screen now has a white glow around the edges, not terrible but noticeable. How do I resolve this?
2-Prior to installing, the loud speaker stopped working, for use with speaker phone and listening to music (without earphones). I thought replacing the faceplate would correct this but it did not. The original damaged portion was at the ear speaker next to front facing camera, which is why I replaced the front plate. I'm thinking the issue is the speakers at bottom, is there any way to troubleshoot?
Thanks all!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
plug your earphones in and see if you hear anything , I just had the same problem and replaced the Loud Speaker and it worked theres little metal flanges on the speaker that need to be tucked in between the speaker and mid frame , if that doesn't do it you may have to replace the Headphone Audio Jack Power Flex Cable
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 152
