Hard drive failed after system crash, now showing as unrecognised
About a month ago, I updated my hard drive for the second time, orgininaly swapping the 110GB HDD for a WD Black 320GB drive back in 2009.
This time I swapped it for a Seagate Momentus XT 750GB Hybrid Drive, and did the same process as before, cloning the MacBooks current OS Drive and then installing the new one. I had about 3 weeks trouble free running, then, while I was in hospital for a couple of days it suddenly crashed on me using safari, and stopped responding.
I held down the power button to turn it off and re-booted it. Afterwards the system almost immediately repeated the same fault and I repeated the process once more, only to find that now I cannot get past a BLANK grey screen, no logo, no folder, no loading wheel.
After eventually deciding there must be an error with the drive, I took it out, put it in an enclosure and thought that if I could atleast back up my data to another drive using my sisters MacBook I can reformat and do a clean install of OSX Snow Leopard.
However, I saw no drive appear in finder, nor in disk utility, I tried a different enclosure (a newer USB 3.0) and it came up with the error message that the drive is unrecognised and I opened disk utility where I would see the listed drive. Requesting Information shows:
Unformatted
Writeable
Ejectable
SMART not supported
Capacity 0 bytes
http://www.flickr.com/photos/lukeysfotos... see link for all info
I have/had irreplaceable information and memories on this drive, work dating back to 2008, a music collection that took 12 years to put together I would appreciate help from anyone who could advise anything I can do to retrieve the data if possible even if it is complicated.
I've had a new idea, I'm scanning my original drive, which has been reformatted since installing my new one to try and recover the files from there, and buy a new drive to trasfer the files to if successful
Questa è una buona domanda?
2 Commenti
UPDATE...
Ive tried using Data Recovery 3 to no avail, using any option deep scan, clone, analysis, etc. produces the error "invalid contents" or "no files on target" I suspect this has something to do with the fact that the the drive hardware itself is registering as 0 bytes, there must be a way to fix this, physically there is 750gb of hard storage, it has to be repairable somehow?
da Luke
You're right - unless the platters have been physically damaged, the data is still present. You're insisting on a DIY cheap "magic" fix. There isn't one. Mayer, and I offered the two most "magical" fixes possible for a DIYer. Only you know the value of the data - having someone (an expert) move the platters from your defunct drive to a new one, or custom drive to retrieve the data is the only solution left. It's neither magical or inexpensive.
da originalmachead
