Card is locked. Help on holidays.
I used the camera yesterday and had no problems. Went to use it today and it says card is locked.
Questa è una buona domanda?
Debbie, check the slide switch on the memory card. Make sure it is not in the locked position. If that does not correct anything, check on here and see if any of those fixes are working for you. Hope this helps, good luck
Thanks for the help. That`s what the problem was. I would have never have thought to look at that piece. Thanks again for the help.
You are welcome:-) glad I could help.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 408
2 Commenti
Did you check to see if it is locked?
da oldturkey03
How do I know if its locked. Its my daughter in laws camera.
da Debbie
