Salta al contenuto principale
Last OS for A1211?
Can I install the Snow Leopard OS in my MacBook Pro 15, A1211, Core 2 Duo, 2.33, 3Gb RAM? I guess the Lion OS is too much right?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Your Mac will handle Maximum MacOS: X 10.7.5
http://everymac.com/systems/apple/macboo...
Here's what Apple says about the system requirements for 10.8:
General Requirements
OS X v10.6.8 or later
2GB of memory
8GB of available space
Some features require an Apple ID; terms apply.
Some features require a compatible Internet service provider; fees may apply.
Supported Models
iMac (Mid 2007 or newer)
MacBook (Late 2008 Aluminum, or Early 2009 or newer)
MacBook Pro (Mid/Late 2007 or newer)
Xserve (Early 2009)
MacBook Air (Late 2008 or newer)
Mac mini (Early 2009 or newer)
Mac Pro (Early 2008 or newer)
Punteggio 6
2 Commenti:
I'm running Mountain Lion on my Santa Rosa system with 4G of RAM without any problems! You should be fine.
da
Earlier machines may indeed take 10.8 but Apple doesn't support them so if you have issues, Apple won't help.
da
Yes, I was running 10.8.2 on my A1226 with no problem.
Punteggio 2
In my experience, the maximun OS is Leopard, 10.5.8. When upgraded my A1211 to Lion, it damaged permanently my Graphic Card (Ati)
Punteggio 0
3 Commenti:
The OS won't damage your GPU, But the GPU in some A1211 fail due to a manufacturing defect as well as pushing the system harder than it was designed to do (over heating it)
da
I have A1211, just upgraded to Lion 10.7.5,I have Ati gpu and had no problems upgrading
da
I wish they didn't lose support for this laptop so quickly... What are ya'll going to do with your old 1211 macs? I don't see a use in keeping it anymore since nothing is supported :(
da
September 2022, installed El Capitan 10.11.6 on A1211. Not by upgrade, but full fresh install (as I understand, the previous owner slightly upgraded it to Core 2 Duo 2.66 Ghz 4 Gb RAM). Everything is working. I tried to install everything from 10.12 up to 10.15, but without success.
So, last MAC OS for A1211 is El Capitan 10.11.6
Also installed as second OS Linux Mint 21, from the first try, works like native.
Punteggio 0
Aggiungi la tua risposta
Mat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 19,526
