Can my logic board by repaired easily? (pic attached)
I spilled a few ounces of protein shake on my keyboard and haven't been able to boot my machine.
I was cleaning the logic board, when I notices that one of the brown rectangle receptacles only had one silver side to it.
Do i need to order a replacement receptacle? Or is the missing silver part soldering material?
Also, a couple of the white dots on the logic board are now brown, or gone completely. Are the tiny white dots necessary for the board to run? If so, how can I add a white dot to the missing space?
Thanks so much in advance!
Update
Thanks!
Questa è una buona domanda?
8 Commenti
Is there any chance you can post a larger image? It is difficult to determine which part you are trying to show us. Also , show us where the part is located in relation to the motherboard. if it requires component repair on the motherboard, then I do have to tell you that it is not an easy repair. It will require good tools and good skills.
da oldturkey03
unfortunately I can only upload an image of 300 x 225 pixels. However, you can see which brown/yellow receptacle i am referring to here:
http://guide-images.ifixit.net/igi/HMAf2...
it is the left most yellow/brown receptacle, about 1 mm from the top of the logic board.
The photo was taken from this site:
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
I am willing to go to any lengths to fix it myself, so any advice is greatly appreciated!!
Thanks!
da Tim
okay, it is not that easy when someone looks at a schematic:-) there has to be a bit of a reference in order to find small components like this. What are the last three of your serial number? this will help to properly identify your computer and the logic board.
da oldturkey03
it looks like this: http://p30upload.com/download.php?imgf=1...
one website said it was a ceramic capicitor... just not sure exactly which kind.
Thanks!
da Tim
Last 3 of serial number: ATM
EMC: 2351
2.4 gHz processor
da Tim
Mostra altri 3 commenti
