Salta al contenuto principale
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
573 Domande Visualizza tutte
open surface pro and change ssd to 256gb ssd
ok after i opened surface pro and with metric duckload glue...... what kind of glue i should use to glue back the screen ?
or do i have to use the same old glue warm it up ? and reglue the screen with ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Heating up and cutting the adhesive will most likely render it useless for resealing the device, so you'll probably want to scrape off the old adhesive with a plastic tool, and use foam double sided tape to reclose the device.
Punteggio 1
I have found that reheating and trying to reuse the old is useless. clean it, get a good 3m double sided adhesive strip set from ebay for like 14 bucks, and do it back together correctly. only way to solve future problems.
Punteggio 0
Aggiungi la tua risposta
julien v sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 7,694
