Salta al contenuto principale
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
driver headlight is dim
i have a problem with my driverside headlight.my daytime lights work until i put my switch on then my driver headlight is dim, when i turn my lights off my daytimes dont work and my headlight indicator light blinks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
andre, check your light bulb to make sure that you have the right one installed. Check your wiring harness for a short. Check your connectors as well as relays for corrosion and make sure that you have proper ground connection.
Punteggio 2
2 Commenti:
1st Step:
Test with an Instrument (Voltmeter),
if the correct or sufficient Voltage is supplied at the Bulb.
Measure at the 2 terminals of the bulb.
If your vehicle has a 12 Volt Electrical System, (DC)
the display at the Test-Instrument should read approximately 12 Volts.
Most "Multi-Meters" are able to measure DC-Voltages.
(Keep well and be kind to each other)
Klaus
da
Often the cause is a bad connection at the bulb-connection.
A bad connection is a Resistance for the electrical current.
This causes a Voltage-drop
and the bulb has insufficient voltage to light up fully.
da
Aggiungi la tua risposta
andre sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,492
