iPad no signs of life
My iPad won't start up. No power on. Not posible to charge. Not posible to be recognized by PC.
Battery have 3.79 volts and not rising when charge directly with profesional Li-Po charger. When battery connected to iPad shows 0.00 volts. When plug in AC on motherboard battery pins shows absolutely no power voltage but on USB and power management area on motherboard shows 3.10V and 5.10V on resistors.
I read that to need be changed capacitors (there are four of them).
I need advice. iPad did not fell down just died middle of working with him.
Thank you
Questa è una buona domanda?
4 Commenti
Have you tired putting it into DFU mode [recovery] then restoring it via iTunes.....?
Just a suggestion as opposed to a technical response...
da James
Hello James,
I tried but no response. I think that motherboard CPU not have power (maybe capcitors don't work as should have).
Thank you for response.
da optisis
Do you want to change the resistors or the coils? Your images are a bit confusing and I am not sure which ones you want to change. You have the capability of repairing this yourself? your iPad is the original iPad or which one is it?
da oldturkey03
not sure...............................................................
da Joshua Sonnenberg
