Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Domanda Chiusa
left part of screen not responding touch
Hello,
Sorry for my english, I'm French.
I dismenteled my iPhone because the Home button wasn't working (it work now :)
But I think I messed with something, probably a cable, because now the extremity on the left of the screen doesn't respond when I touch it. (It's 3 millimeters on all the height)
So I can't press the a, q, shift, and the key for acceding the numbers on the keyboard when the phone is vertical.
Do you think there is a chance I can correct the probleme by opening the phone again and move the cables if they aren't well placed or it will just get worse?
Because after that I'm a little scared of opening it again :/ it was a very bad idea to open it in the first time, so I don't want to open it again for nothing.
And if there is nothing to do, do you know a solution for typing the caracter with my problem? maybe an app, or cydia app who can modify the original keyboard?
Thank you for reading me
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
titousky, the only way to get it fixed is by opening it again, sorry. It is possible that the cable from the digitizer is tore, or not properly seated. It is my experience that if a certain part of the digitizer is unresponsive, the digitizer itself has a broken circuit. this means that you will have to replace the front display. Follow this guide for the repair. Hope this helps, good luck.
Punteggio 0
Im having that same problem and i repalced the digitalizer twice but still left side edge dont work? Were you able to fix it?
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,944
