Salta al contenuto principale
Hewlett-Packard ha iniziato a produrre personal computer di tipo laptop nel 1993.
3324 Domande Visualizza tutte
Display is dim even when plugged in.
My HP Pavilion has a feature that dims the display when on battery power. I used the thing on battery for just a short time and went home and plugged it in. It normally brightens when plugged in but is staying dim. I am wondering if the battery must be 100% before it brightens up again.
Questa è una buona domanda?
Punteggio 1
3 Commenti
It should brighten up the moment it is plugged in. Have you checked your AC power supply to make sure it is okay? Does your battery charge?
da
Well yes it does charge..based on some other forums Im looking in it could be the power supply and indeed the outlet I am using also..the outlet could have low voltage. It may also brighten when the battery is fully charged..
da
I know this is probably stupid but ill ask it anyway, did you check your power plan? didnt you change your plan to power saver or smth like that, one that has half the luminosity of your old plan ?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
thanks you guys! I went to battery settings and adjusted brightness..dont know how it changed itself..but its fixed..thanks to you all! its appreciated..have a great day!
Punteggio 2
1 Commento:
good job in getting it fixed. all you have to do now is to accept your own answer. this way anybody looking for the same issue will know what works. :)
da
Aggiungi la tua risposta
chuck rowland sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 15,748
