Salta al contenuto principale
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Domande Visualizza tutte
Domanda Chiusa
The temperature is about 90° and once it reaches 100°
sorry!
my friend give to me an old powermac g5 for big problem.
after mac os start, the temperature is about 90° and once it reaches 100° goes in protection.
i see no fluid loss, but i think the problem is with cooling.
any idea? thanks
this is solution? http://www.saunalahti.fi/~holindho/g5-qu...
really thanks
Questa è una buona domanda?
Punteggio 0
2 Commenti
Is that 90 degrees F or C
da
is celsius degrees :(
probably i have to change water pump and get new liquid! it is not easy but I groped with the link step.
if I succeed, I will proceed with the calibration fan with ASD Dual Boot 2.5.8
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Run your Apple Hardware Test (AHT) from the original system installation disk. Hold down the "D" key on start up with the disk installed and see if its the coolant or possibly one or more of the fans.
Punteggio 2
3 Commenti:
i will try, but all fans are going fast...
thanks for support
da
finally find asd but now the g5 won't start :(
his make fan check, and monitor don't show nothing :(
da
no moore idea?
really thanks
da
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 12
Tutti i Tempi: 368
