Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Domande Visualizza tutte
Domanda Chiusa
A1181 MacBook ID help, Not sure which one I have? Please Help?
Hello,
Im ready to up grade my ram and HD on my A1181 Macbook with a 2 GHz Intel Core 2 Duo. When using Apple's online service assistant and putting in my Serial Number, It does not show any specifics of year and whether it is a Santa Rosa, Penryn, etc etc. Although It appears from cross referencing your product Id numbers that the ram and HD's ifixit sells can work on a number of A1181 Macbooks, I would like to know what my specific mac is so i can ensure Im buying the correct product. As said before my MacBook is an A1181, 2GHz Intel Core 2 Duo, 2 gig memory, and SN is W8903LVV4R1. Thanks in Advance,
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Dom, does this look right to you:"
Intro Date: January 20, 2009 Disc Date: May 27, 2009
Order No: MB881LL/A Model No: A1181 (EMC 2300)
Subfamily: Early 2009 Model ID: MacBook5,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 120 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
Processors: 1 (2 Cores) Geekbench: 2719/3072*
Processor Speed: 2.0 GHz Processor Type: Core 2 Duo (P7350)
The Intel "Core 2 Duo" (P7350) 45 nm "Penryn" processor includes two independent processor "cores" on a single silicon chip.
Plenty of more details about it right here
This from the manual about your memory:" This computer comes with a minimum of 2 GB of 667 GHz Double Data Rate 2 (DDR2)Synchronous Dynamic Random-Access Memory (SDRAM) installed. It has two slots that can accept SDRAM Small Outline Dual Inline Memory Modules (SO-DIMMs). The slots are side-by-side on the logic board behind the RAM door. For best performance, memory should be installed as pairs with an equal memory card in each slot. The maximum amount of memory for this computer is 4 GB, with 2 GB DIMM installed in each slot.
Memory cards must meet these requirements:
• 1.25 inch or smaller
• 1 GB, or 2 GB
• 200-pin
• PC-5300 DDR2 667 MHz Type RAM
Punteggio 2
Thank you so much that sounds like it! You are awesome!! Time to upgrade!
Punteggio 0
1 Commento:
Thank you for accepting my answer. All the best to you and welcome to ifixit ;)
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 860
