I replaced the logic board, and the click wheel shuts it off.
After replacing the logic board (with the guide), now every time I use the click button, or switch the hold switch, it shuts off the ipod.
Questa è una buona domanda?
sonicsean89, double check your connectors and make sure the locking tab's are down and that the cables are in straight and are properly seated. Sounds like it is shortening out. IF nothing else, replace the click wheel. If you still have problems with it, contact the vendor and see if you can get the logic board replaced Hope this helps, good luck
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 145
