Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
Domanda Chiusa
Question about reball skywork chip
is there thermal grease between both parts of the chip?
or is it done by cleaning the gold shining surface and reball it?
http://cdn.smartphone-parts.com/images/T...
got the same problem with the chip, it broke into pieces
Skyworks SKY77541 module soldering
in the meantime, the new chip arrived and I will try to solder this
desolder the nonfunctioning chip. there seems to be only solder on the outside. but what about the contact sufaces in the middle?
Questa è una buona domanda?
Punteggio 0
3 Commenti
Thx for information oldturkey
think my chip is broke into two pieces :(
da
Unusual. Take a couple of images and post them with your original question, lets see:-)
da
okay
I have not reballed already because I'm not sure if the big surfaces are coated with solder or with something else?
has anyone had experience with it already?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
There is only one part. Your image shows the front and back of the chip. Here are some great instructions about reballing a BGA. Also check this video, different chip, same idea. The stencils for a reball are available at places like this. Hope this helps, good luck.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 633
