Salta al contenuto principale
Home button seems to be pressing by itself?
The home button on my iPod Touch seems to be pressing by itself.
If I open any app it will just close after a few seconds as if I pressed the home button. Also, when I'm not in an app it will just flip back and forth between the search screen and the list of apps as if I was pressing the home button.
The button does not seem to be physically jammed because when I do press it you do feel and hear it click. And the button does work.
One other note..if I press down either to the right or left side of the home button it does act as if I did press the button.
Any ideas on this? Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
If this is a 3rd generation Touch, I'd take it back to Apple, as it should still be under warranty.
Punteggio 1
did you find a solution? myn is doing the same.
Punteggio 0
1 Commento:
Edited to remove email address (for security reasons
da
Aggiungi la tua risposta
Keith Maurino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,192
