Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
265 Domande Visualizza tutte
Domanda Chiusa
Will any MacBook Pro SATA drive cable fit 13" Retina MacBook Pro?
I'm wondering if the SSD cable in the 13" Retina MacBook Pro (Late 2012) can be replaced with a SATA optical or HDD cable from a non-Retina MacBook Pro. Specifically, if the SATA header on the 13" Retina MBP mainboard is compatible with other MacBook Pros to facilitate adapting SATA and/or mSATA drives to the 13" Retina MBP for a cheaper upgrade solution.
don't bother arguing if an SSD can fit in the location or not as it has no bearing on the question, so please stick to the specifics of the question asked, thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No - it uses a proprietary synchronous NAND instead of the more commonly utilized Asynchronous NAND connector. I don't know where you'd find one.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,451
