Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
251 Domande Visualizza tutte
Is the SSD disk the same in MacBook Pro 13" and 15"?
Hi!
Is there any differences between the SSD discs on 13" and 15"?
My 13" retina got jägermeister all over and died completely. Now I'm buying a 15" retina and I want to know if it's possible to replace the hard drive with the one in the broken 13" so that i don't loose all my valuable data.
Best regards,
Mikkel Christiansen
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
OWC makes a Envoy drive which you can put your stick in an read it via USB. They make a couple of different ones for the different sticks so check before buying. You can then transfer your data and use the old stick for storage. I think this is the one you need: http://eshop.macsales.com/item/OWC/MAU3E...
Punteggio 2
After reviewing the applicable teardowns, I see no reason why you couldn't swap drives. That being said, the 15" comes with twice the storage, so I'd recommend just transferring said data to your new Mac.
Cheers!
Punteggio 0
Aggiungi la tua risposta
Mikkel Christiansen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 467
