Salta al contenuto principale
Model A1213 / 8, 16, or 32 GB capacity
216 Domande Visualizza tutte
Domanda Chiusa
Many problems with iPod Touch 1G
Hi to everyone. I have a many problems with my iPod Touch 1G:
1. iPod can't turn off. He make restart. I make restore but don't work.
2. The sound from earphones is very low. I clean up the jack with cotton but doesn't work.
3. iPod doesn't sound from the speaker. I mean the sounds from keyboard and another.
This is for the moment.
PS. Can I repair headphone jack?
Questa è una buona domanda?
Punteggio 0
1 Commento
I make downgrade to 3.0, but nothing change.
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
1) Try doing a "Hard Reset" hold "Lock" and "Home" until it reboots, then see if it will restart, and shut down normally.
2) Check the "Volume Limit" in Settings>Music>Volume Limit, then see if this fixes it.
3) Check the settings for the clicker in Settings>General>Sounds, and make sure that the things that you want to make sounds on are turned on.
The headphone jack is attatched to the logic board. You could try to de-solder it, and attatch a new one, but you may want to just replace the logic board, and solve all of the problems in one fowl swoop, or upgrade to a new iPod Touch.
Punteggio 1
5 Commenti:
1) Don't work.
2) Don't work.
3) All is on.
da
It may have a bad logic board, you might want to try replacing it, or restoreing it. What Firmware does it have? you can check at settings>general>about, you may want to download an older firmware like 3.0 for a more stable OS without compromising any important features
da
da
It may just be a hardware problem, you could consider replacing the logic board, or the iPod. Has it ever been wet, or dropped from a decent height?
da
Hi to everyone, I have a problem with the Home button of my iPod touch 1st Generation. I can´t press it, I want to know how to change this component.
Thanks
Punteggio 0
i did repair my home button
because ipod touch 1g got this problem
,,, the key of home button is ok but it dosent reach the button the only way to fix it ...
open it then put a little cut of paper into the key
Punteggio 0
you can buy hephone jack and soldered it
i have this problem also
and i fix it ...
Punteggio 0
'''I have the ipod touch 1st generation..
My ipod won't turn on, it's not dead.. I can't plug it into the computer.. It's just dead. Is it broke or is there anyway possible to fix it..?!'''
Punteggio 0
1 Commento:
taylor, your question shows as an answer to a question that is a year old. If you expect some help with your problem, please click on the link to the right hand side of this screen "Ask a Question" it is not hard to do and will get you the help you need with your iPod. This will also give you the opportunity to describe your problem better.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 7,349
