Salta al contenuto principale
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Domande Visualizza tutte
dropped ipad, bent the alluminium case on the volume bottom
I've just dropped my ipad and the alluminium case bent on the volume button, i cant use the volume button and it stuck inside (volume square is frozen on the sceen). Is it possible to open the ipad and reshape the allumium case or is it too risky?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi Lou,
As you have probably noted, there is no screw to open the iPad 2 and in fact it make opening this iDevice much more complicate that an iPhone for example.
This is the reason why all iPad 2 guides are marked "Very difficult"!
I wouldn't say it is too risky, it depends on you, your skills and probably also your tools. If you want to make a good job you will have to use the good tools. Look at this iOpener at least!
  • If you decide to access the volume button hole from inside the rear case, the minimum require disassemble is the display. Look at this guide so you will have a better view on what you would have to do.
  • Once you will have the screen out, you will have a better view if further dis-assembly is required. Any further dis-assembly should be piece of cake after what you've done just before!
  • Also remember that you're gonna have to re-install the screen with new adhesive strips after that. (New adhesive strips available here.)
Let us know what is your decision, and good luck!
Immagine iPad 2 Adhesive Strips
Prodotto
$6.99
Immagine iOpener
Prodotto
iOpener
$19.99
Immagine iPad 2 CDMA LCD
Guida
iPad 2 CDMA LCD Replacement
Difficoltà:
Molto difficile
40 minutes - 2 hours
Immagine iPad 2 CDMA Front Panel Adhesive Strips
Guida
iPad 2 CDMA Front Panel Adhesive Strips Replacement
Difficoltà:
Moderato
Punteggio 2
If the case is bent in the volume control area you can just use pliers to unbend the case. Be careful and use a cloth pad to avoid scaring the case. In my case (pun intended) the thin aluminum above the cutout part of the case was bent and Apple wanted almost as much as a new one to repair it.
Punteggio 0
Aggiungi la tua risposta
Lou sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,744
