Salta al contenuto principale
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Domande Visualizza tutte
Domanda Chiusa
Logic board lcd connector thin metal cover came off a little
Hey guys,
While replacing the HD on my late 2009 imac i7 2.8g I may have messed up the LCD connector to the logic board.
I have attached a picture (from the ifixit guide) of the part i'm referring to.
Here is what happened. The cover to the connector is in 2 pieces that cover the front of the connector. The right half of the cover came off. If it still connected, however it's lose.
I'm wondering if that is going to be a problem. I hope it wont be but I think you guys can better tell me if i just completely screwed up my iMac or not.
Thanks!
J
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
as long as it works and you are sure the connector will not come off while reassembled inside the machine i think it should be fine.
Punteggio 0
2 Commenti:
I'll know for sure if it works when i get home. I'll update in case this happens to anyone else.
Thanks for the response!
J
da
Well... It does seem to work. I'm doing a timemachine restore now.
One of the rubber pieces on the connector came off too... That cable and its connector are horrible!
da
i messed up with mine today ... i broke some pins on the connector ... i assume that i must replace the hole logic board..
Punteggio 0
1 Commento:
or have someone solder a new connector to your board.
da
APPLE imac 27 inch internal lcd connector FI-X30SSL-HF
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 500
