Salta al contenuto principale
Domanda Chiusa
Plastic next to hinge is broken
MacBook Air Model A1304
Hi ...I had a broken plastic part and it's happened again. This time the plastic piece that looks like the back of a folder is cracked down the middle. Where Can I buy this part? What would I call it?
PLease somebody where get it or in fixit where is ? Its sells alone or comes with the case
Thanks
Questa è una buona domanda?
Punteggio 0
1 Commento:
Please give us the last three figures of your serial number so we know your exact machine and get you to the correct parts. Thanks
da
Aggiungi un commento
1 Risposta
You may search by "Clutch cover" for MacBook Air Model A1304. You can buy it at http://www.powerbookmedic.com or also can search at eBay or may be iFixit also has it if you search by the name I mentioned. Make sure that you are getting the item exactly for your Air model.
If you find this answer useful, please rate and mark it as accepted. Thanks.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 714
