Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2396 Domande Visualizza tutte
Component Identity required please!
Is it necessary?What does it do?Where can i order it?Are you sure it's a connector?Because the connector seems to be the one on the right.I want to know more about that golden one, where i could buy one?
Questa è una buona domanda?
Punteggio 0
1 Commento
Yes, the brass one is a connector....;-)
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
john they are available at places like this as well as places like this. I believe the manufacturer is murata and the part number is MM4829-2702. The datasheet is available right here. Hope this helps.
Punteggio 2
This is a antenna . By this you phone connected with Network. this component is necessary for a working phone. without this phone will not connect to carrier. it will stay in no service or searching .
Punteggio 1
2 Commenti:
I have a second hand Iphone and this component is missing and the blue inductor is also missing.The phone is always searching with no service.Where I could buy or order these two components?
da
You can remove these from any non working phone .
da
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 343
