Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Domande Visualizza tutte
Domanda Chiusa
Socket on motherboard fallen apart
Hi,
I was replacing a fried airport card in my MacBook, and while removing the cable that connects the reed switch to the motherboard, the littler socket it fits into basically disinigrated and all of the metal pins fell off as well as the plastic surrounding them. Is there any way to replace this socket without having to replace the whole motherboard?
This is causing the MacBook not to sleep when the lid shuts and erratic behaviour she in sleep mode.
Many thanks in advance...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You can try sending in the Logic Board to www.Powerbookmedic.com . They have a repair program for logic boards. Otherwise you would need to replace the whole board.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 189
