Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
20 Domande Visualizza tutte
My Screen is White and Glitching
So I dropped my Ipod and when I checked it, there were no cracks, the touch screen works perfectly and so does the button. However, there is a small grey spot near the left side corner and wont clear up. It didn't do anything at first until I was changing songs and then my whole ipod glitched. The top half of the screen looks normal, but the bottom half glitches to this white smoky color. I tried resetting it and everything but nothing worked. I went into settings and into general and into reset. I reset the network settings. The white smoky-ness disappeared, but that gray spot remains. I don't want my ipod to glitch again after it is now working. I don't even want to turn it off in fear of the glitching. Please help! What should I do??
Questa è una buona domanda?
Punteggio 4
4 Commenti
I have that glitch too except the grey line gets bigger everyday and forming into a little grey patch. I did the same by turning it off and on but it's still there. I don't use my iPod for much except reeading. I use my phone to listen to music. What should I do? Please help!
da
I just dropped my iPod and it has a glitch to the side of the screen how do I fix it
da
hey i droped my ipod today and its gliching every where there is not spot where i can see my ipod
da
My ipod is doing the same thing but I tried turning it off but it didn work
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
This might seem counter-intuitive, but you should figure out exact what causes it to "glitch".
Hold the iPod at each corner and try twisting it (gently but firmly) in different directions. If this causes it to glitch, it's probably physical damage or a loose connection inside of your iPod.
Try pressing on the iPod in different parts, such as the corner with the grey spot and all over. If any of these cause it to glitch, then something is loose or damaged.
Turn it off and on, reset your settings, mess with the wireless options, try playing games, and so forth. If it seems like any specific settings or games or things like that are causing it to glitch then you might try a backup and restore, and if that doesn't work then just a restore.
Hopefully that helps!
Punteggio 0
Risposta Più Utile
Same things happened to my iPod so I tried pressing the whole iPod screen, it's takes time. Then I found the part that was making it glitch and the screen started working fine. So what I'm trying to say is press the whole screen and wait till u find the part that is making it glitch
Punteggio 1
My ipod is glitched, it says i have 24.123.567 minnutes to wait before i can enter my code. What do i have to do?? Pleasse Help
Punteggio 1
1 Commento:
That also happened to my iPod yesterday. Since I didn't want anything but the photos because I hadn't used the iPod in ages, I synced my photos on iTunes on my laptop and clicked 'Restore iPod'. It took around half an hour but don't forget to update iTunes before restoring it as it won't work if it isn't updated. Also don't forget to plug your iPod into the computer haha
da
i need help my ipod keeps glithing out alll the time i tryed everything and the appstore is not working to should i buy a new ipod pay someone to fix it help !!!!
Punteggio 0
2 Commenti:
Ok so my ipod got hit with a bat and my screen has all different colored lines like a glitch someone help plz
da
my ipod got hit and now there is grey and white and black line someone help
da
Aggiungi la tua risposta
Eri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 7,076
