Salta al contenuto principale
La linea di computer portatili MacBook Pro di Apple per utenti avanzati e professionisti. La linea MacBook Pro include varianti da 13, 14, 15, 16 e 17 pollici, e le revisioni principali sono definite da Pre-unibody (originale), unibosy, display Retina, Touch Bar e SoC (system-on-a-chip).
20008 Domande Visualizza tutte
Cracked glass panel on the MacBook Pro 13" 2012
So, Ive done my research and from how the mac book pro is made, It appears that only the outer glass panel is cracked. There are a couple minor cracks near the upper part of the screen and only one of them actually is on the screen and the camera still works fine with no cracks or problems. But since there are no problems with the picture or the LCD screen its self I don't think it will need to all be replaced. The cracks are unseen from about 10 feet away. Now many question....How Much with this cost to fix? and Who should I have fix it? (Apple or Third party or DIY)
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Only you know how much money you want to put into repairing it. The most expensive place IMHO would be Apple - you can look for quotes on the web or at your local computer repair shop. You could even DIY (after all this is the DIY repair site). The glass is integral to the LCD so as a DIY repair replacing the entire LCD would be the way to proceed.
If this answer was helpful please remember to mark it accepted.''
Punteggio 1
1 Commento:
I agree with Machead - An authorized Apple repair shop would be my first choice as they tend know where to get the needed parts effectively. Apple directly would be the most costly. Only you know what your skills set is if you decide to take this on your self. It's best to replace the entire LCD unit as Machead pointed out. But, it is possible to remove the cover glass. It's not the best job for a beginner to tackle.
da
Aggiungi la tua risposta
Ben Toles sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,661
