Salta al contenuto principale
iPod touch 3g will not turn on what will I do
my apple ipod touch 3g it has just gone blank i was downloading a song off itunes and it just went blank i thought it may of ran out of batery so i pluged it in and not eaven the charging thing came up when i held the power button what should i do try and fix it or buy a 5th gen
Questa è una buona domanda?
Punteggio 1
1 Commento
Does it charge ? If not, have you tried a different cable ?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
conor, try a hard reset first. To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button at the same time for a minimum of ten seconds, then the LCD display will clear and the Apple logo should appear on the black background. Once the logo appears, your iDevice is reset.
Punteggio 1
1 Commento:
But what if that doesn't work?
da
Your charge battery could've run out of charges
The charge battery has a limited amount of uses until it needs to be replaced
Punteggio 1
1 Commento:
Ryan Ckit, why does it remain lifeless when it is plugged in? How do you suggest to fix it?
da
Aggiungi la tua risposta
conor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,749
