Salta al contenuto principale
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
89 Domande Visualizza tutte
Is there a way to tighten-up/more resistance the analog sticks?
I am trying to find a way to tighten-up or give more resistance to the analog sticks of the controller. In two areas, first in the amount of pressure that it takes when pushing it down .... i would like to make it stiffer/harder. Second, in the left to right movement in the analog stick, in order to reduce the sensitivity during game-play.
As it stands right now i just barely tap the stick, left or right and it travels way past the intended target, forcing another tap the other way to correct it ........... ant ideas?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
maxx, I just took a look at the analog controller and I do not see anything that would allow any adjustment. I would suggest to replace the stick with a set of new ones. They are relatively inexpensive and it only requires basic soldering skills to replace them. Hope this helps, good luck.
Punteggio 2
Aggiungi la tua risposta
maxx sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 79
Tutti i Tempi: 7,374
