I successfully accomplished dismantling my Vaio DUO 11. It was in a mad rush after my wife spilled coffee on the keyboard. Despite her folly, she did the right thing and immediately flipped the computer upside down to prevent the coffee from spreading to the internals any further.
A few things you need to know.
1. Remove all exterior covers INCLUDING THE SPEAKER MESH!
The speaker mesh is two layers, and one layer will be ruined upon removal, but the top layer will be salvageable, use a knife to pry it off. There are 3 rubber bumpers that are attached by adhesive; rip them off. 2 flat plastic covers. The other covers are replaceable, but basically everything that can come off, must come off (except the folding feet, just flip those up to access the screws beneath.
2. Keep track of your screws
I was in haste so didn't label anything, which is not exactly necessary except for a few odd silver colored ones. MAINLY KEEP THE EXTERIOR SCREWS SEPARATE FROM THE INTERIOR SCREWS. I made the mistake of not doing this, and so after reassembly, my count of screws was correct and I didn't miss any, but I was left with short screws outside where I needed longer ones. So as long as you keep your exterior screws separated, then you'll figure the rest out.
3. Don't force it.
I made the mistake of removing some unnecessary screws. For the most part if they are not attached to a circuit board then they do not need to come off. I found that a few unnecessary screws had incredible resistance. So if they are fighting you, then you probably do not need to remove them; unless you need to remove the monitor mechanism.
4. Use the quick releases
I tried to avoid removing board connecting ribbons, but it would have gone a lot smoother if I had used them and left a few things in place
5. Pry
The motherboard in particular has some sticky pads beneath it, so after the screws are removed it will require a bit of force to remove; don't be scurred'.
As far as the SSD, you do not really need to remove the motherboard to get to it. There are a few ribbons and stuff in the way, and it has it's own screws along with a sticky pad beneath it. Once the screws are free just lift it off the sticky pad and pull it out. There are no latches or anything. It is a lot easier to remove than the keyboard, since the keyboard was beneath everything.
I'm not 100% sure as I'm not a computer guy, but you may want to disconnect the battery before removing the SSD. It just connects to the motherboard with a recessed pin connector, so you can just remove a few screws so you can pry it a little, just enough so the battery disconnects.
Basically just try it, if you put it back together and there are some extra screws it is not the end of the world. I'm an HVAC mechanic and we are accustomed to just taking crap apart and putting it back together. JUST DO IT. Step #2 is really all you need to know.
If you are curious about the coffee incident, then here is more about it. There is only one way to clean a keyboard of sticky liquid, and that is more liquid. Yes, I rinsed my keyboard with hot water after it was removed. I dried off most of the water with a blow dryer and then set it in a bag of rice for 24 hours. I figured it was already ruined from coffee so a water rinse was worth it; I had nothing to lose. Now my keyboard is working like a champ; it needed the cleaning anyhow.
Unfortunately I did not take any pictures of the process, but you can email me with any questions.
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
2 Commenti
Please let me know how you do with this project. I imagine a ssd install would not be too complicated.
da revRocks22
Please let me know, I also looking how to remove Cover Panel for Sony Vaio DUO 11
da Edwin
