Salta al contenuto principale
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Domande Visualizza tutte
Can I add hard disk drive in Mac mini with fusion drive?
Hi,
I have 2 linked questions.
Is there still the space to add a hard disk drive in Mac mini with fusion drive or is this area filled by fusion drive?
If it's possible did the additional hard disk drive will be considered as part of one disk or will it appear as another hard disk drive with no benefit of fusion drive?
Thanks for your answers :)
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It would appear as a second HD and AFAIK not have any benefit of the fusion drive. See this article
If this answer was helpful please remember to mark it accepted.
Punteggio 1
3 Commenti:
Thanks but there is a point I still don't know. Where in physically the SSD drive in mac mini fusion drive? I'm afraid it use the area for second hard disk drive?
da
You're correct reports are the fusion drive uses one of the drive bays.
da
A Fusion Drive is two physical drives (1 HD & 1 SSD) which via software made as one contiguous volume. You need to use two SATA Ports and drive storage spaces to create a Fusion Drive.
da
Risposta Più Utile
After digging through the manuals for this machine, it appears that the Fusion drive configuration uses both drive bays. The SSD goes in the lower bay and the standard hard drive goes in the upper bay (these bays appear reversed when you're in the machine).
If you ordered the machine without a fusion drive, you still have an empty bay.
Punteggio 2
Aggiungi la tua risposta
glenic sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,629
