Salta al contenuto principale
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Domande Visualizza tutte
Why won't my sterio work?but did before?
i put a cd player in my car before and switched it out for a newer cd player.now that i put a new one in it won't work.i double checked to make sure all wires where right and fuses...What else could it be for it not to work?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Is it an aftermarket stereo or a Toyota brand? Do you use an amp with it? What was the issue with the old one? You just replaced it to go with a newer player?
da
i just replaced the stereo for a newer one. there is no amp connected.ok i will check the wires again..thank u both very much
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First thing I would do is test the power wire to the stereo with a volt meter and see if you are getting 12 volts from it and at the same time make sure the Ground source is also working, if that is good I would look for a fuse that is in the stereo itself and see if it's good, if that's all good then I would have to think the stereo may be bad.
Punteggio 0
Aggiungi la tua risposta
gamesnotwar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 326
