Salta al contenuto principale
LCD not working Horizontal lines
Hello My 2006 Macbook Pro 2006 one day started with horizontal unreadable lines on screen. Works on another monitor. Not sure if its LCD Bad, Logic board bad, Video cable, video inverter
Any direction as to what problem is would be grateful thanks
Questa è una buona domanda?
Punteggio -1
1 Commento
Thank you for your info I will check cables already checked cable to computer need to check cable to LCD
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If an external monitor works fine you can rule out the VGC and logic board, look into the cables and the LCD screen itself. If the unit was damaged (dropped or screen forced back to far - weak or loose hinges) the display data cable could be cut/nicked or loose. Overheating of the CPU can also sometimes cause this... clean the inside and inspect the video cable.
If this answer was helpful please remember to mark it accepted.
Punteggio 1
Aggiungi la tua risposta
Robert Meyers sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 599
