Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Display is color inverted and garbled
I replaced my iPhone 4's sticky home button following the instructions on this site. I've put everything back together and now the screen is inverted and garbled.
What's the likely cause? Did I damage the ribbon cable?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sadly You could have damaged the ribbon cable or flexed and ruined the LCD during removal, either way you will need a new LCD Digitizer . Good Luck.
Punteggio 2
5 Commenti:
Yeah, I figured as much. Not really worth fixing when a whole refurbished iPhone 4 can be had for less.
da
Dang, where do you find a refurbished I 4 so cheap ?
da
Actually that's not even refurbished!
da
And that would be with a contract.
da
Aggiungi la tua risposta
Marcus Harvey sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 511
