How can I fix this?
My Ipod touch 4th gen. screen was broken and I repaired it. Now when I try to turn it on, a white screen shows up.
Questa è una buona domanda?
make sure all the connectors are connected and try doing a iTunes restore
do you sure the konectore scren put correctly? make sure the screen type corect too
If the LCD connectors are properly connected then try resetting your device by pressing and holding home and power button until the screen goes black and turns on again. If this thing doesn't help then you may need to go for LCD replacement.
Did you bother to look at the date the question was asked? I doubt bakerkylee still has a problem here.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 227
