Salta al contenuto principale
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
slow SSD speed with Dual Hard Drive Kit
I just installed a Crucial C300 in my mac mini using the Mac Mini Dual Hard Drive Kit.
While cloning the HDD to the SSD using CarbonCopyCloner (which I've used successfully multiple times on a MacBookPro and a MacPro), the SSD suddenly disappeared and won't show until a 10 minutes "cooldown".
I then tried to copy 4Go files to the SSD from the HDD, and every 10 seconds the copy stalls for 30 seconds.
Can it be a faulty cable? or is it a Sata speed issue (as seen on some MacbookPro using 3G data SSD)?
EDIT: I've tried with another SSD (a Crucial M4 and a Samsung 840) , and it worked perfectly. So it seems that the Crucial C300 is not "supported"
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It may be unsupported or just a bad drive. Contact Crucial to see if the drive is supported.
Punteggio 2
Aggiungi la tua risposta
Boris T sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,394
