Broken glass on Microsoft Surface
Do you know where I can buy a replacement glass for the Surface ? The glass is cracked but the screen is ok, I can still use it...
Questa è una buona domanda?
http://www.mylcdtouchscreen.com/
Sells just the glass for a good price
Mike Asseraf, "LCD and glass are fused together" from here . This usually means that it is almost impossible to replace one without the other. Check on here for a replacement. Still costly but the only ones I found thus far.
So I have somewhat the same problem. By boyfriend stepped on my tablet cracked the screen but the screen is not functioning :( if I purchase the replacement for the screen and lcd would it fix my problem? Would it work 100% properly? Please answer ASAP I was going to purchase this today.
I'm not sure that you will find in the internet anything. Because the surface is new the only way to find spare parts as the glass you should take your surface where you bought it.
Yes, I know it's hard but I don't have the choice... I live in Israel, bought my Surface in New York... And the only option I have is to pay $300 to Microsoft to have my Surface replaced... But when you live 8000 km from the store it's quite difficult :) So iI must find a way to buy the glass and have my Surface repared in Israel.
Mike -
I am looking to replace my Surface glass also. I saw your post and just want to tell you that I wish you and all your countrymen THE BEST!!
I could never understand the hardships you and/or others must be facing now - physically, emotionally, locally amd abroad.
What I can tell you is that the media does not reflect the majority of Americans. WE STAND WITH ISRAEL ALL THE WAY!!!!!!!!!!!!!!!!
Oh my! It's my problem too. If the glass screen is cracked & it is still functioning well, is it possible that the LCD may be affected too? I'm in the Philippines & the gadget is from Australia.. What should I do?? :(
have you found a solution to your problem? I have the same exact problem. My surface pro 4 glass cracked and I need to have it repair but I also live in the Philippines.
I have the same problem! I accidentally dropped it on concrete and it cracked :'(
Is there anyway to replace the screen without replacing the whole thing , in malaysia
hi Andrew we all have the same problem, based on my research you can purchase your replacement surface pro screen at aliexpress.com
of couse you can, here is the lcd i found on google search result
ciabate@gmail.comhi there l want a new placement glass for my 7 touch screen andriod tablet
could you send a free 7 touch screen andriod tablet in the post my address his flat 108 twinnell house stapleton road easton bristol from mrs marcia bate
cold you plase send the 7 touch sreen andriod tablet urgently in post to flat 108 twinnell house stapleton road easton bristol
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 22
Tutti i Tempi: 32,600
3 Commenti
how i can buy a Surface rt glass ? The glass is braked but the screen is still working , I am still using. i am looking for best way how can i buy it, in U.A.E quite difficult to find Surface parts.
da Abdul Hannan
there are a string of posts all asking the same question, where to buy the screen components.
it seems no one has the answer, so what is the point of this forum then?
we have the usual blind chasing the blind.
da roly
Hello, we just bought a Microsoft Surface Pro 3 1631 LTL120QL01 12" LCD Touch Screen Digitizer AssemblySurface Pro 3 screen from Ebay "China" with free expidated shipping.
I wil llet know the quailty of the item.
da Billy Sherlock
