Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
Domanda Chiusa
Only top of screen is visible, rest is white/negative
After replacing the battery and re-assembling my ipod touch 4th gen, only the top of the screen (where the battery status indicator is) is visible, the rest of the screen is bright white/negative colored but i can still read the text. All other functions are good. I tried to disassemble the ipod twice but the screen remains the same. Is this the LCD or something else?
Thanks in advance!
Greets.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Its the lcd.
Punteggio 1
I have an Ipod touch in my shop right now with the same issue. I pressed the home button fairly hard 3-5 times fast and the colors shifted back, not sure if this will salvage it but worth a shot.
Punteggio 0
1 Commento:
Thanks for the answers! I tried to press the home button as you said but this didn't solve my problem, I ordered a new LCD yesterday so I hope this helps
da
yes, you can put the "invert colors" function for better readability on the triple home button click. but then the display would be completely inverted. since only a part of your screen is inverted it is definitely a broken lcd.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 423
