Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
Domanda Chiusa
Light is on but no ones home!
Had fan problems, so I took it apart to clean it
In my venture. I broke my socket to the memory board.
Not having a hole lot to use I siliconed it in place.
All put back together , plugged it in turned it on and 10 seconds later it shuts off. So on a new venture. Took it back apart. Not having arctic past I used dielectric past. Checked everything for visible damage. Carefully adjusted prongs on power board. I put it back together and now the red lights on but nothing happens when I hit power. Please help.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Ok so I did the thermal arctic silver.... Cleaned board,
And tried my soldering skills.
Now it turns on. Yay!!!
But it won't load my black ops that I have previously
downloaded. Every time it tries it I get a black blank screen.
Ahhhhhhhhhhhhhhhhhhhhh!!!!
PLEASE. HELP.
da
Jeremy, what did you solder?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
So you used dielectric paste which is a lubricant instead of Arctic paste which is a thermal compound? You also used silicone to glue the connector back on, which is an insulator as well? My suggestion would be to disassemble your PS3 and start cleaning it with a high grade isopropyl alcohol, remove all of the silicone and the dielectric grease. Then apply a thermal paste like Arctic silver and solder your connector properly unto the logic board. RE-evaluate after you get those repairs accomplished.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 580
