Salta al contenuto principale
iPod Touch 3g Battery
Is the battery plugged in or soldered?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
7 Risposte
Risposta Più Utile
It is soldered to the board, as seen in the picture on step 12. Also, the battery uses a thin ribbon cable whose solder points are essentially holes through the ribbon cable itself, so it is difficult to solder but definitely possible (I've done it before).
Punteggio 4
1 Commento:
Thanks appreciate the help
da
Its definatley soldered however I am trying to source a new battery anyone know where to get one?
Punteggio 0
after removing the Battery ribbon, will you see three lines with solder on them? because i think i overheated it and removed a metal plate.
Punteggio 0
1 Commento:
You (and Richie) should ask your questions here: http://www.ifixit.com/Answers/Ask
da
I just joined this forum and did this myself on my 2nd gen iPod touch and it is my believe that one of the three battery connection or solder points, specifically the middle one, does not have a solder plate or line underneath it like the other two, which were very easy to solder back on, but the middle one gave me the impression I overheated and removed it, but there are no traces of a plate in the middle, not even at the old battery's middle connection point.
Punteggio 0
how to check the battery
Punteggio 0
1 Commento:
marcooliveira30, you will get more assistance on here if you ask a question the proper way. Click on the link on the right side of this page "Ask a question" and give as much detail as possible. Right now your question appears as an answer and not to many people look at questions that are over a year old. If you really want some help with that just ask the question the right way. Thank you and good luck
da
my name Donell Kuykendall just turn your wifi off and try to put your ipod touch on airplane mode or try to lower the brightness. thats how you get better battery
Punteggio 0
The three points all have metal connection which need solder!! if you over heat the board its hard but if you roll the solder directly below to the gold point you will return the connection!! you can also slip the lifted pad back in place and solder the two outside points down then solder the middle one last and this will actually hold it down and keep connection as well.
Punteggio 0
1 Commento:
if you want to advertise your business, please don't do it on here. Put your website address in you profile.
da
Aggiungi la tua risposta
carlb48 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 17,333
