I am unable to here voice in palm pre plus
When i answer any call unable to here voice when i switch it to loudspeaker i am able to here, that is my phone problem.
can any one solve the my problem ASAP.
Questa è una buona domanda?
surya, sounds like a blown earpiece speaker. Check this video for instructions. For further repair guides check on here. Hope this helps, good luck
I've run into this on my Pre+ and Pre 2 and often it's the sensor in the headphone jack not working correctly. The phone thinks a headset is still plugged in even when one isn't. This usually happens to me after I've had headphones or a cable plugged into the phone.
Short of taking the phone apart to clean or repair the piece in the headphone jack, I usually plug and unplug something into the jack until it manages to fix itself. I'll try playing music using the music player: if it's playing but you don't hear anything out of the speaker, the phone still thinks a headset is plugged in. Once the headphone sensor correctly identifies nothing plugged in, you will hear the music on the phone speaker.
Hope this helps!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 449
