Salta al contenuto principale
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
How can I completely remove the screen?
I want to remove the screen from my PowerBook G4 so I can use the base as a computer attached to my TV without any loss of functionality (I understand Airport and the Bluetooth antennas are connected to the screen?) All help appreciated!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I would follow the directions for removal of the LCD screen first as described here: PowerBook G4 Aluminum 17" 1-1.67 GHz Display Replacement
Then you should be able to remove the hinges.
Punteggio 2
You can separate your display assembly from your bottom case using the link mayer posted in his answer then open the display and remove the airport/bluethoot antenna cable. Simply reconnect the cable to your logic board and you will restore the wireless functionality.
Punteggio 2
Aggiungi la tua risposta
Dave Robertson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,302
