Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Domanda Chiusa
Which part to buy to fix sleep button
I have an iPhone 4 and the sleep button does not press or work anymore. Don't see any damage around it but I know it's a common issue. Just wondering which part I need to buy form your site. I believe you have just the button listed and the entire electronics with the button. Not sure if just replacing the metal button part will fix it. Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Buy the cable not the metal button. its called the power and sensor cable. it is for the sleep button but it also connects to the rear camera cable. check out there teardown for the power button and you will see in the last step the power sensor cable. Buy that!!
hope this helps
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 363
