Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
"Searching..." constantly after opened up? and no battery life.
So basically, my Lock Screen button broke some time ago, so i opened up the back to see if anything was lodged and it wasn't, i saw tutorials on the internet about opening it up, so i disconnected ONLY these 3 point of the phone, as i had no real reason to carry on, from what i can work out, it was the Battery Connector, Antenna Connection and Charging Connection.
I put all these back fine, im no expert but im sure they are in place well.
When i turned it on, it constantly said "Searching..." and doesnt even go to "No Service". so i opened it up again, to make sure it was connected, and pushed it all down.
But now, it only seems to run off the power from the charger, it has no intake from the battery.
I thought id try one last time last night to make sure it worked, and i got it to work with the battery, but when i woke up it did it again. So i thought it was time to ask the Pros, ideas? All i wanted was the Lock Screen button fixed haha
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
Check date/time if set to 1970, it's the ios 6 bug
Fix it by setting date right
Punteggio 2
salam...
I am not so sure about your battery problem but double check by replacing your battery or battery connector. whereas about the searching part I have been having the same problem with after replacing display assemblies for some of my customers and most of the iphones were repaired and fixed by restoring only maybe its a bug or an an apple hole for all of us to fall in or its just me.
Malik.
Punteggio 0
There is about 7 different trouble shooting you can do.
Call the phone
Call out from the phone
set date/time
take your sim card out put someone eleses in it then put your one back in
reset phone
leave the phone alone for 10min dont touch it
Thank god for the IOS 6.0.1 that has just came out, hopfully that has fixed the bug
Punteggio 0
Do you have the new IOS6 update???
If so, just use another phone to call your mobile. Not sure why this works but i haved now repaired 6 4s with this new update and after i repaired them they all had the searching come up, now i just call the number and it kinda like resets the reception.
hope this helps
Punteggio -1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,167
