Salta al contenuto principale
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 Domande Visualizza tutte
Laptop not turning On when pressing power Button
When I press on Power Button only the media player touch LED blinks once and the light for caps and numlock continuously blinks even I can see power on DVDROM and fan too moves . But none of the LED in front blinks and no power on monitor is there.
Could you please suggest me what should I do.
Questa è una buona domanda?
Punteggio 2
2 Commenti
can you attach an external monitor and see if you get anything? Any post beep's?
da
Use this : Dell AC Adapter LA90PM130
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thanks for your Suggestion "oldturkey03"
I have troubleshooted it and found the reason, its because one of my RAM has gone Bad.
Regards,
Amit Lal
Punteggio 0
Some times the Heat sink & fan gets dust and due to which system gets heated.
Once cleaned can help overheating & abnormal switching off issue.
Punteggio 0
Aggiungi la tua risposta
Amit Lal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,991
