Salta al contenuto principale
Modello versione metà 2009 A1278 - EMC2326 / processore Core 2 Duo 2,26 o 2,53 GHz
745 Domande Visualizza tutte
May have accidentally bent this cable - What does it control?
Just installed a SSD in my MacBook Pro 13" Unibody Mid-2009. I also chose to remove my optical drive and install a hard drive in its place. While doing the installation, I had some trouble re-inserting a cable, and fear that I may have inadvertently bent it slightly. It's a large/fairly thick cable near the fan on the motherobard; I had to remove it in order to access a screw that's underneath it.
The machine *appears* to be working fine, everything I've tested so far (sound, wifi, etc.) appears to be working as it should. What is this cable for (i.e. is there something I can test to see if it's working or not)?
Picture of the cable I'm talking about is below. Thanks!
Questa è una buona domanda?
Punteggio -1
1 Commento
Yup, that's the iSIght cable all right. Thanks. Luckily I didn't damage mine; my iSight still works perfectly. Thanks for your answers!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
dburr, I wonder if it is the camera cable. It might be more visible if you could zoom out a bit and give more of a location. Of course, I am not a Mac person, so I could be way off:-)
Punteggio 3
That is the camera cable.
Have a look at step 10 of this guide:
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
I just had a rough time unplugging mine while removing the logic board.
Punteggio 2
Aggiungi la tua risposta
dburr sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 564
