Salta al contenuto principale
Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
89 Domande Visualizza tutte
Replacing broken keys -- is it possible?
This is a great description/teardown. One question: the "L" key on my keyboard came off. I tried to replace it following the insights in the teardown (realize teardowns are not a repair guide!) but not sure if it's possible and wondered your opinion. The part that came off was the plastic cap that has the letter printed on it. The rubbery thing underneath (the piece that holds the key suspended over the button, so to speak) was still in place, so I pried that off with a sharp point. Then tried to join the plastic cap to the rubbery piece, but with no luck. In fact, I broke the little plastic tabs on the back of the plastic cap trying -- so pretty sure it's destroyed for good. Question is, any idea what I did wrong? Is this situation fixable? In your teardown, did you manage to salvage a working "L" cap that coud be purchased? Thanks again for a great explication of this otherwise pretty good piece of hardware. Kevin
Questa è una buona domanda?
Punteggio 2
1 Commento
Sorry Bob -- just getting hang of iFixit. This was the Apple Wireless Keyboard that is referred to in the teardown at Apple Wireless Keyboard (A1255) Teardown
The guy who did the teardown had a bunch of extra keys, or so he mentioned. Of course, that was two years ago .... ;-)
Thanks for your answer!
Kevin
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
You did not specify a model. Try Machina Electronics. The link is:
http://www.machinaelectronics.com
The keys are nor expensive. They ship by U.S. Mail. You can usually find installation instructions on the web site.
I have had success replacing broken laptop keys from Machina.
Punteggio 1
It is absolutely possible to replace/repair broken or mission laptop keys. Check out http://www.laptop-keys.com for a full selection of keys and helpful repair videos.
Punteggio 0
Aggiungi la tua risposta
Kevin McKean sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 10,881
